21. Routing Protocols
21.1. OSPF & RIPv2
The Peplink supports OSPF and RIPv2 dynamic routing protocols.
Click the Advanced tab from the top bar, and then click the Routing Protocols > OSPF & RIPv2 item on the sidebar to reach the following menu:
OSPF
Router ID
This field determines the ID of the router. By default, this is specified as the WAN IP address. If you want to specify your own ID, enter it into the Custom field.
Area
This is an overview of the OSPF areas that you have defined. Clicking on the name under Area allows you to configure the connection. To define a new area, click Add. To delete an existing area, click on the Delete.
OSPF Settings
Area ID
Assign a name to be applied to this group. Machines linked to this group will send and receive related OSPF packets, while unlinked machines will ignore them.
Link Type
Choose the type of network that this area will use.
Authentication
If an authentication method is used, select one from this drop-down menu. Available options are MD5 and Text. Authentication key(s) may be input next to the drop-down menu after selecting an authentication method.
Interfaces
Select the interface(s) that this area will use to listen to and deliver OSPF packets.
To access RIPv2 settings, click on Edit.
RIPv2 Settings
Authentication
Interfaces
Select the interface(s) that this area will use to listen to and deliver RIPv2 packets.
OSPF & RIPv2 Route Advertisement
SpeedFusion VPN Route Isolation
Isolate SpeedFusion VPN peers from each other. Received SpeedFusion VPN routes will not be forwarded to other SpeedFusion VPN peers to reduce bandwidth consumption.
Network Advertising
Networks to be advertised over OSPF & RIPv2. If no network is selected, all LAN / VLAN networks will be advertised by default.
Static Route Advertising
Enabling OSPF & RIPv2 Route Advertising allows it to advertise LAN static routes over OSPF & RIPv2. Static routes on the Excluded Networks table will not be advertised.
21.2. BGP
Click the Advanced tab along the top bar, and then click the BGP item on the sidebar to configure BGP.
Click the "x" to delete a BGP profile.
Click "Add" to create a new BGP profile.
BGP Profile
Name
This field specifies the name that represents this profile.
Enable
When this box is checked, this BGP profile will be enabled.
If it is left unchecked, it will be disabled.
Interface
The interface in which the BGP neighbor is located.
Router ID
This field specifies the unique IP as the identifier of the local device running BGP.
Autonomous System
The Autonomous System Number (ASN) assigned to this profile.
Neighbor
BGP Neighbors and their details.
IP address
The IP address of the Neighbor.
Autonomous System
The Neighbor's ASN.
Multihop/TTL
This field determines the Time-to-live (TTL) of BGP packets.
Leave this field blank if the BGP neighbor is directly connected, otherwise you must specify a TTL value. This option should be used if the configured Neighbor’s IP address does not match the selected Interface’s network subnets. The TTL value must be between 2 and 255.
Password
(Optional) Assign a password for MD5 authentication of BGP sessions.
AS-Path Prepending:
AS path to be prepended to the routes received from this Neighbor.
Values must be ASN and separated by commas.
For example: inputting "64530,64531" will prepend "64530, 64531" to received routes.
Hold Time
Wait time in seconds for a keepalive message from a Neighbor before considering the BGP connection as stalled.
The value must be either 0 (infinite hold time) or between 3 and 65535 inclusively.
Default: 240
Next Hop Self
Enable this option to advertise your own source address as the next hop when propagating routes.
iBGP Local Preference
This is the metric advertised to iBGP Neighbors to indicate the preference for external routes. The value must be between 0 and 4294967295 inclusively.
Default: 100
BFD
Enable this option to add Bidirectional Forwarding Detection for path failure. All directly connected Neighbors that use the same physical interface share the same BFD settings. All multihop Neighbors share the same multihop BFD settings. You can configure BFD settings in the BGP profile listing page after this option is enabled.
Network Advertising
Select the Networks that will be advertised to the BGP Neighbor.
Enable this option to advertise static LAN routes. Static routes that match the Excluded Networks table will not be advertised.
Custom Route Advertising
Additional routes to be advertised to the BGP Neighbor.
Advertise OSPF Route
When this box is checked, every learnt OSPF route will be advertised.
Set Community
Assign a prefix to a Community.
Community:
Two numbers in new-format.
e.g. 65000:21344
Well-known communities:
no-export 65535:65281
no-advertise 65535:65282
no-export-subconfed 65535:65283
no-peer 65535:65284
Route Prefix:
Comma separated networks.
e.g. 172.168.1.0/24,192.168.1.0/28
Filter Mode
This field allows for the selection of the filter mode for route import.
None: All BGP routes will be accepted.
Accept: Routes in "Restricted Networks" will be accepted, routes not in the list will be rejected.
Reject: Routes in "Blocked Networks" will be rejected, routes not in the list will be accepted.
Restricted Networks / Blocked Networks
This field specifies the network(s) in the “route import” entry.
Exact Match: When this box is checked, only routes with the same Network and Subnet Mask will be filtered.
Otherwise, routes within the Networks and Subnets will be filtered.
Import Default Route
Enable this option to import the default route from BGP neighbors.
Import only from origin ASNs
Import only routes originated by the specified ASNs. Enter one or more ASNs, separated by commas (,).
Filter Mode
This field allows for the selection of the filter mode for route export.
This field specifies the network(s) in the “route export” entry.
Export to other BGP Profile
When this box is checked, routes learnt from this BGP profile will be exported to other BGP profiles.
Export to OSPF
When this box is checked, routes learnt from this BGP profile will be exported to the OSPF routing protocol.
Redistribute BGP Default Route to OSPF
Enable this option to redistribute the BGP default route to OSPF.
On this page
