14. OpenVPN
OpenVPN is a site to site VPN mode that can encapsulate a wide variety of network layer protocols inside virtual point-to-point links over an Internet Protocol network.
To configure an OpenVPN, navigate to Advanced > OpenVPN and click the New Profile.
OpenVPN Profile Settings
Name
This field is for specifying a name to represent this OpenVPN profile.
Active
When this box is checked, this OpenVPN connection profile will be enabled. Otherwise, it will be disabled.
OpenVPN Profile
Upload the OpenVPN configuration (.ovpn) file from your service provider.
Login Credential (Optional)
This option is optional for you to enter the username and password to log in for the OpenVPN connection if the profile needs to log in.
Connection
Select the appropriate WAN connection from the drop-down menu.
