16. Device Level Tools
Device Level Tools covers the Settings menu of an individual device. These screens act on one device only, and several of them override or opt out of the group settings. Two entries, Remote Web Admin and Web CLI, open the device's own interface instead of an InControl 2 screen.
Menu entries by product and state
  • The device Settings menu is not a fixed list. The entries depend on the product type and the state of the device.
  • An access point does not show the router only entries, and a device with no Wi-Fi radio shows no Wi-Fi entries.
  • On an offline router, Remote Web Admin, Web CLI and Device Tools stay in the menu but are greyed out and cannot be opened. InTouch, Firmware Management and Certificate Management remain available. The greyed entries become available again when the device is back online.
  • An AP One has no Web CLI entry. When it is offline, its Remote Web Admin and Device Tools are greyed out.
  • A FusionHub lists Firmware Management, Certificate Management and Device Tools.
  • A missing entry reflects the product type or device state. This is expected and does not indicate a fault.
Device > Settings on an offline router, dropdown outlined in red. Remote Web Admin, Web CLI and Device Tools are greyed out. InTouch, Firmware Management and Certificate Management remain available.
16.1. Firmware Management
Firmware Management sets the firmware for one device. The device either follows the group policy or is pinned to a version, for example to test a release before a group rollout or to keep one site on its current version. To set firmware for many devices, use Group > Settings > Firmware Policy (13.9 Firmware Policy (Group Level)), which lists Devices not following the policy: beneath its grid.
Where to find it
Device > Settings > Firmware Management
Firmware Management. The Applying Firmware dropdown is the only editable field, and Current Schedule below it records the last scheduled update.
16.1.1. What This Screen Shows
Field
What it shows
Device
The device name, as a link
Product
The product model
Hardware Revision
The hardware revision of the device
Existing Firmware
The version and build currently on the device
Applying Firmware
The dropdown that sets the firmware the device should run
Update Schedule
When the change is applied, for example Immediately. See Update Schedule below
16.1.2. Applying Firmware
The top of Firmware Management. Applying Firmware reads Firmware management disabled, and Update Schedule reads Immediately.
Option
What it means
Follow group policy
The device uses the firmware set by the group firmware policy
InControl 2 does not manage firmware on this device
A version and build
Pins the device to that firmware. The list offers the versions available for this product
Custom
Takes a firmware URL instead of a version from the list. See Custom below
Reboot to last firmware
Returns the device to the firmware it ran before the current one. The option names that version in brackets
If a device does not operate correctly after an upgrade, select Reboot to last firmware to return it to the version named in brackets.
The version list differs by product and hardware revision.
16.1.3. Custom
Selecting Custom adds three items to the screen.
Custom selected. The Firmware URL field with its Verify control and the warning about group policy, outlined in red, appear beneath the dropdown, and Update Schedule gains its three radio buttons.
What appears
Notes
Firmware URL:
A text field for the address of the firmware file
Verify
A control beside the field. It checks the address entered rather than setting a value
A statement on the page
It reads: the device will not follow the Group policy, and it will not receive the firmware specified on the group policy page
To return the device to the group firmware policy, select Follow group policy.
The Upgrade only checkbox and the Update Schedule radio buttons also appear with the URL field. Both are described below.
16.1.4. Upgrade Only
Upgrade only qualifies the firmware selected above. It sets whether the running version must be older before InControl 2 applies the specified one.
State
What InControl 2 applies
Selected
The specified firmware is applied only if the running firmware version is lower than the specified one
Not selected
The specified firmware is applied only if the running firmware version is different from the specified one
When selected, a device already running a newer version is left unchanged. When cleared, the specified version is applied to that device as well, because a newer version is a different version.
Upgrade only appears once a firmware selection is made. It is not shown while Applying Firmware is set to Firmware management disabled.
16.1.5. Update Schedule
Update Schedule sets when the selected firmware is applied. Like Upgrade only, it offers controls only once a firmware selection is made. With Applying Firmware set to Firmware management disabled, the screen shows the single word Immediately and no controls.
Once a firmware is selected, Update Schedule offers three radio buttons:
Option
Notes
Immediately
Applies the firmware as soon as the change is saved
Scheduled
Applies the firmware on a schedule rather than at once
Entering a geo-fence
Applies the update when the device enters a geo-fence rather than at a set time. This suits vehicles: the update waits until the device enters a geo-fence, for example a depot, rather than running mid route
Scheduled requires a schedule, and Entering a geo-fence requires a geo-fence.
16.1.6. Current Schedule
Current Schedule with one entry. It shows the targeted build, when the update was scheduled with its time zone, and a Status of Completed.
Column
What it shows
Firmware version
The version and build the update targeted
Scheduled Date and Time
When the update was scheduled, with the time zone
Status
The outcome, for example Completed
Action
Per row actions for that schedule entry
16.1.7. Controls on This Screen
Control
What it does
Applying Firmware
Selects the firmware policy for this device
Firmware URL:
Takes the address of the firmware file. Shown only when Applying Firmware is set to Custom
Verify
Checks the address entered in Firmware URL:. Shown only with Custom
Upgrade only
Restricts the change to a device running a lower version. See Upgrade only above
Update Schedule
Selects Immediately, Scheduled or Entering a geo-fence
Save Changes
Applies the selection. Greyed out until a change is made
Cancel
Discards the selection
Device name link
Returns to Device Details for this device
16.2. Certificate Management (Device Level)
Certificate Management loads the private keys and certificates that one device presents, by category, for example its web admin certificate. The captive portal certificate and the MediaFast CA certificates are managed at group level.
Where to find it
Device > Settings > Certificate Management
Certificate Management. One row per category, with the two notes below the grid explaining what happens to categories left blank.
16.2.1. What This Screen Shows
One row per certificate category.
Column
What it holds
Category
The purpose the certificate serves on the device
Private Key (pem encoded)
A text box for the pem encoded private key. Treat keys entered here as confidential
Key's Passphrase
A text box for the key passphrase, marked Optional. Treat the passphrase as confidential
Certificate (pem encoded)
A text box for the pem encoded certificate
Action
Clear for most rows, and Auto Set Up on the Web Admin row
Three categories are offered:
Category
Action offered
SpeedFusion VPN/IPsec VPN
Clear
Web Admin
Auto Set Up
OpenVPN
Clear
16.2.2. Controls on This Screen
Control
What it does
Clear
Removes the key and certificate held for that row. Greyed out while no certificate is loaded. Leaving a row empty is not the same as clearing it: as the screen states, for categories with no certificate defined, the existing private keys and certificates on the device remain unchanged
Auto Set Up
Offered on the Web Admin row only. See Auto Set Up on the Web Admin row below
group level
Opens the group level certificate screen, where the captive portal and MediaFast CA certificates are managed
Save Changes
Applies the entered keys and certificates. Greyed out until something is entered
Cancel
Discards the entries
16.2.3. Auto Set Up on the Web Admin Row
The certificate grid. On the Web Admin row the Action column holds the ticked Auto Set Up box and its information icon. The other two rows offer Clear.
Auto Set Up replaces manual certificate handling for the web admin interface. Its tooltip states:
  • InControl automatically acquires a web admin SSL certificate from letsencrypt.org for the Find My Peplink Address.
  • It does so every 76 days and installs the certificate to the device.
The installed certificate covers the Find My Peplink Address. If the device must present a name you control, load your own key and certificate into the Web Admin row instead.
16.3. InTouch
InTouch gives access from InControl 2 to cameras, controllers and other equipment on the LAN behind this device, over http, https, ssh, telnet, rdp or vnc, under a saved name rather than a raw address.
Entries are per device and describe equipment on the LAN behind it. This screen defines entries. Saved entries are opened from the InTouch panel on the group dashboard, where they appear as InTouch profiles arranged by group or by device, each listed by name as a link. See Group Dashboard, 10.1.7 The InTouch Panel.
Where to find it
Device > Settings > InTouch
InTouch Settings. The IP-based grid is empty until entries are added, and Save Changes is greyed out until then.
16.3.1. What This Screen Shows
The screen holds one grid, IP-based.
Column
What it shows
InTouch Device Name
The name given to the entry. Each saved name is a link
Note
Free text recorded against the entry
URL on LAN
The protocol, host, port and path of the equipment on the LAN
Group Name
The group the entry is filed under
Accessible by Viewers
Whether viewers may open the entry
Action
Per row actions for that entry. Three icons: the first carries the tooltip Clone, the second is a waste bin, and the third is a play icon. On an offline device the play icon is greyed out and carries the tooltip Device is offline
An empty grid shows No data available.
Two saved entries in the IP-based grid. Each name is a link, and the Action column holds a clone icon, a waste bin and a play icon. Copy settings to... sits beside Add.
16.3.2. Adding an Entry
Add opens the entry editor.
The Add dialog. The InTouch Device Name field is at the top, and the URL on LAN row is built from four separate inputs.
Field
Notes
InTouch Device Name
The InTouch Device Name field at the top of the dialog. Required, and outlined in red until filled
URL on LAN
Built from four parts on one row: a protocol dropdown, then three inputs whose placeholders read hostname/IP on LAN, port and path (optional). The row shows the separators :// and : and / between them
Basic Authentication
A checkbox on the row below URL on LAN, cleared by default
Compatibility Mode
A checkbox with an information icon. See Compatibility Mode below
Group Name
A text field whose placeholder reads Optional
Accessible by Organization and Group Viewers, and InTouch Users
A checkbox that sets who, in addition to administrators, may open the entry. Tick it to allow read-only users or customers to open the entry. Leave it clear for equipment that only administrators should access
Note
A text area whose placeholder reads Optional
The protocol dropdown offers http, https, ssh, telnet, rdp and vnc, so entries are not limited to web interfaces.
Three inputs are marked optional in their placeholder text: the path at the end of the URL on LAN row, Group Name and Note. The name at the top is the only required field.
16.3.3. Compatibility Mode
Compatibility Mode is for equipment whose interface does not display correctly through InTouch. Its tooltip states:
  • Enable one of the HTTP compatibility modes if web pages load incompletely or appear broken.
  • Enable the WebSocket compatibility mode if live streaming content, for example video or dashboard data, cannot be loaded.
  • The compatibility modes are disabled by default.
Leave it off unless an entry does not display correctly, then select the mode that matches the symptom.
16.3.4. Controls on This Screen
Control
What it does
Add
Opens the entry editor
Copy settings to...
Beside Add. Opens Copy InTouch Settings to..., which offers a Group selector, a Device selector, a Remove settings from the source device checkbox, and Copy and Cancel. Use it to give a new site the same InTouch entries as an existing one
OK
Accepts the entry in the editor
Cancel (in the editor)
Closes the editor without adding the entry
Save Changes
Saves the grid. Greyed out until an entry is added or changed
Cancel
Discards unsaved changes to the grid
Caution: Ticking Remove settings from the source device in Copy InTouch Settings to... removes the entries from this device. Leave it clear unless the entries are to be moved rather than copied.
16.4. Device Tools
Device Tools runs a ping, traceroute or other single command on this device from InControl 2.
Device Tools works on one device at a time, and only while the device is online. For many devices, use the group equivalents: Restore to factory defaults..., eSIM Installation... and Download diagnostic reports... in the Actions menu of Group > Settings > Device Management (13.1.7 What Each Entry Opens), Scheduled Reboot in Group > Settings > Device System Management (13.4.8 Scheduled Reboot), and Group > Network Settings > Connection Tests for scheduled tests, including SpeedTest (8.16 Connection Tests). Results of scheduled tests are in Group > Reports > Connection Test Reports (11.10 Connection Test Reports). Reports remain available for an offline device. See Device > Reports > Event Log, Offline History and Online History (15.9.3 Offline History and Online History).
Where to find it
Device > Settings > Device Tools
Device Tools. The screen holds one Command dropdown and shows nothing else until a command is selected.
16.4.1. What This Screen Shows
  • A single field, Command, holding a dropdown that opens on Please select....
  • Nothing else is shown until a command is selected. The rest of the screen then appears beneath the dropdown.
The dropdown offers eight commands:
  • Ping
  • Traceroute
  • eSIM Installation
  • eSIM Deletion
  • WAN Performance Analysis Server
  • Remote Assistance
  • Reboot
  • Reset to Factory Defaults
Selecting a command does not run it. Each command first shows its own fields or controls.
  • Ping, Traceroute and eSIM Installation each ask which connection on the device to use (Connection or WAN).
  • Reboot and Reset to Factory Defaults show an Apply button.
  • eSIM Deletion shows an eSIM picker and a Delete button.
  • Remote Assistance and WAN Performance Analysis Server show the switches described below.
The Command list expanded. eSIM Deletion, outlined in red, removes an eSIM profile from the device.
Reboot, Reset to Factory Defaults, eSIM Deletion and Remote Assistance also ask for confirmation before they run.
Caution: Reboot takes the site offline until the device restarts, and Reset to Factory Defaults erases the device's configuration, including its WAN settings. Confirm the device before clicking Apply, and read the confirmation before accepting it.
Speed tests are scheduled under Group > Network Settings > Connection Tests (8.16 Connection Tests), and the results are viewed in Group > Reports > Connection Test Reports (11.10 Connection Test Reports).
16.4.2. How to Isolate a Fault from InControl 2
  1. 1.Run Ping from each WAN in Connection to a public address. If one WAN fails while the others pass, the fault is with that ISP or link.
Step 1. With Ping selected, select the WAN in Connection and enter the address in Destination(s), both outlined in red, then click Start. Output appears under Results.
  1. 2.Run Traceroute from the failing WAN to find where the path stops.
  2. 3.Run Ping from LAN (VLAN 1) to equipment at the site to check the LAN side. Destination(s) accepts more than one address per run.
  3. 4.If the equipment has its own interface, open it through an InTouch entry.
Step 4. Saved InTouch entries, each listed by name as a link in the InTouch panel on the group Dashboard.
  1. 5.Reboot only if the steps above point to the device itself.
16.4.3. Ping
Ping selected. Four fields, then the Start, Stop and Clear Log controls, and a Results area that reads No record until a run produces output.
Field
Type
Notes
Connection
dropdown
The connection on the device the ping is sent from. The list is built from the device's own connections, so it differs between devices. For example: LAN (VLAN 1), WAN and an SFC relay client entry
Destination(s)
text area
A text area, so more than one destination can be entered. Separate entries with a space or a new line
Packet Size
number
Default 56
No. of Times
dropdown
1 through 10
Control
What it does
Start
Runs the ping
Stop
Ends a run in progress
Clear Log
Clears the output
Output appears in a Results area beneath the controls. It reads No record until a run produces output.
16.4.4. Traceroute
Traceroute selected. It takes a single Destination rather than the text area Ping offers, and has the same Start, Stop and Clear Log controls.
Field
Type
Notes
Connection
dropdown
The same list of the device's own connections that Ping offers
Destination
text
A single line field. One destination per run
Traceroute has the same Start, Stop and Clear Log controls and the same Results area as Ping.
16.4.5. WAN Performance Analysis Server
Field
Type
Notes
On / Off
switch
Turns the server on or off on this device
Control Port:
number
Default 6000
The screen notes: Leaving this screen will stop the server after 60 minutes. A device that does not support the feature shows This device does not support WAN Performance Analysis.
16.4.6. Remote Assistance
Field
Type
Notes
On / Off
switch
Turns remote assistance on or off for this device
Turn off after [n] days. Disallow direct connection.
radio
Remote assistance ends after the number of days entered
Allow direct connection. Remote assistance remains enabled until disabled manually.
radio
Remote assistance stays on until it is switched off manually. Switch it off when it is no longer needed
The form ends in Apply and Cancel.
To turn Remote Assistance on for a set number of days, or off, for several devices, use Remote assistance... in the Actions menu of Group > Settings > Device Management, which offers Turn off after a number of days (13.1.7 What Each Entry Opens).
16.4.7. eSIM Installation
eSIM Installation installs an eSIM profile from an eSIM provider on one cellular WAN of one device, remotely. To install profiles on many devices at once, use eSIM Installation... in the Actions menu of Group > Settings > Device Management (see eSIM Installation in the Group Settings chapter, 13.1.9 eSIM Installation).
eSIM Installation selected. The WAN dropdown names the cellular WAN and the slots in use, the three installation methods are radio buttons, and the form ends in Submit rather than Start.
Before you start:
  • The device must be online. Device Tools is unavailable on an offline device.
  • The device needs EssentialCare or PrimeCare. Without it, the form shows EssentialCare or PrimeCare is required for eSIM installation. in place of its fields.
  • Keep another WAN connected to the Internet, such as Ethernet, Wi-Fi WAN or USB. A physical SIM in the same cellular module cannot serve as that connection.
16.4.8. How to Install an eSIM
  1. 1.Open the device and go to Device > Settings > Device Tools.
  2. 2.In Command, select eSIM Installation.
  3. 3.In WAN, select the cellular WAN that receives the eSIM. Each entry reads like Cellular 1 (Used slot: 0/4): the eSIM slots already in use on that WAN, out of the maximum it holds. When every slot is used, the form shows Sorry, up to [n] eSIMs can be installed. Please delete one and try again. and hides the rest of the form. Remove one with eSIM Deletion first.
  4. 4.Under eSIM Installation Method, select the method that matches what the eSIM provider supplied. The table below compares the three.
  5. 5.Provide the profile:
  • Input manually: paste the activation code from the eSIM provider into the text area. If the provider also issued a confirmation code, enter it in the field below. Then click Submit.
  • Scan: click Scan and hold the provider's QR code up to the camera.
  • eSIM Discovery: no entry is required. Click Acquire.
eSIM Installation with Input manually selected. The text area for the activation code and the optional Confirmation code field are outlined in red.
  1. 6.Wait while the device downloads the profile. The form's controls lock and a progress message, such as Downloading..., appears beside the button.
  2. 7.Read the result beside the form:
  3. 8.Confirm that the Used slot count for that WAN in WAN has increased by one. Then check the state of the cellular WAN in the WANs block of Device > Device Details (14.1.10 Status).
  • eSIM profile installed successfully. after Input manually or Scan
  • [n] eSIM(s) discovered and installed. after eSIM Discovery
  • Failed to install eSIM profile. with a reason, when it did not complete
eSIM Installation with eSIM Discovery selected. The text area and confirmation code field are replaced by the note and the Acquire button, outlined in red.
Method
What it needs
Button
Input manually
The activation code from the eSIM provider, plus its confirmation code if one was issued
Submit
Scan
The provider's QR code and a camera on the computer or tablet running InControl 2, with camera access allowed in the browser. Scan is greyed out when the browser finds no camera
Scan
eSIM Discovery
A profile the provider has already linked to the device's EID. InControl 2 describes it as Acquire purchased network operator profile automatically. Offered only on devices that support it
Acquire
16.4.9. eSIM Installation Fields
Field
Type
Notes
WAN
dropdown
One entry per cellular WAN, each naming the slots in use, in the form Cellular 1 (Used slot: 0/4)
three radio buttons
Input manually, Scan and eSIM Discovery. Exactly one applies
Text area
text area
Shown for Input manually. Takes the eSIM profile, which is the activation code from the eSIM provider. Required
Confirmation code
text
Shown for Input manually. Its placeholder reads Confirmation code (Optional). Leave it empty unless the provider issued a confirmation code
The form states that an active Internet connection is required during eSIM installation.
Caution: Because installation needs an active Internet connection, deleting the only working eSIM on a device can leave no connection over which to install a replacement. Before using eSIM Deletion, confirm the device has another working WAN.
The form ends in Submit, or Acquire for eSIM Discovery. Progress and the result appear as a message beside the button.
16.5. Remote Web Admin
Remote Web Admin opens the device's own web administration interface from InControl 2, outside the InControl 2 screens. For the contents of that interface, refer to the documentation for the device firmware.
Where to find it
Device > Settings > Remote Web Admin
The device Settings menu, opened by hovering over Settings. Remote Web Admin and Web CLI are outlined in red. The arrow on Remote Web Admin opens a list of direct links to pages of the device's own interface.
Hover over the arrow beside the entry to list shortcuts to individual pages of that interface, such as Dashboard, Network > WAN and Advanced > Port Forwarding.
Remote Web Admin opens the device's own Dashboard, with its own menu bar (Dashboard, SF Connect, Network, Advanced, System, Status). This is the device's interface, not an InControl 2 screen.
16.5.1. What It Does
  • Reaches the device's own settings page through InControl 2, including devices behind carrier NAT.
  • Opens the web administration interface served by the device itself.
  • Opens directly to the device's own Dashboard. No separate device login page is shown.
  • The device must be online. The entry is greyed out and unavailable on an offline device.
  • All pages shown belong to the device, not to InControl 2. Using it changes no InControl 2 screen, and changes made there are made on the device.
Caution: For Wi-Fi AP SSID and Radio, SpeedFusion VPN, Outbound Policy, Firewall Rules, Web Admin Settings and Time zone, where InControl 2's management option is enabled, changes made on the device are reverted and overwritten by InControl 2, as Group > Settings > Bulk Configurator states (13.12.1 What the Page Tells You First). Check the badges on Device > Device Details (14.1.2 Status Badges on the Heading Line) first, and make lasting changes in those areas in InControl 2.
16.6. Web CLI
Web CLI opens a command line session on the device from InControl 2, outside the InControl 2 screens. For the available commands, refer to the documentation for the device firmware.
Where to find it
Device > Settings > Web CLI
The device Settings menu, opened by hovering over Settings. Web CLI is outlined in red, below InTouch.
16.6.1. What It Does
  • Opens the device's own command line interface in the browser.
Caution: Remote Web Admin and Web CLI both open sessions through InControl 2, but a change made in either is made directly on the device, not in InControl 2's configuration. The caution under Remote Web Admin about areas InControl 2 manages also applies here (16.5 Remote Web Admin).
On this page
