Appendix F. Troubleshooting
Problem 1
Outbound load is only distributed over one WAN connection.
Outbound load balancing can only distribute traffic evenly among available WAN connections if many outbound connections are made. If there is only one user on the LAN and only one download session is made from his/her browser, the WAN connections cannot be fully utilized.
For a single user, download management applications are recommended. The applications can split a file into pieces and download the pieces simultaneously. Examples include: DownThemAll (Firefox Extension), iGetter (Mac), etc.
If the outbound traffic is going across the SpeedFusionTM tunnel, (i.e., transferring a file to a VPN peer) the bandwidth of all WAN connections will be bonded. In this case, all bandwidth will be utilized and a file will be transferred across all available WAN connections.
For additional details, please refer to this FAQ:
https://forum.peplink.com/t/8-2-0-speedfusion-dynamic-weighted-bonding-explained/40223
Problem 2
I am using a download manager program (e.g., Download Accelerator Plus, DownThemAll, etc.). Why is the download speed still only that of a single link?
First, check whether all WAN connections are up. Second, ensure your download manager application has split the file into 3 parts or more. It is also possible that all of 2 or even 3 download sessions were being distributed to the same link by chance.
Problem 3
I am using some websites to look up my public IP address, e.g., www.whatismyip.com. When I press the browser's Refresh button, the server almost always returns the same address. Isn’t the IP address supposed to be changing for every refresh?
The LAN-to-Internet traffic will be routed following the outbound policy rules. On the current firmware, the default “Auto” rule uses the lowest latency algorithm to route traffic. Therefore, it may use the same WAN that has the lowest latency to reach the website.
For additional details on the outbound policy, please refer to this FAQ:
https://forum.peplink.com/t/understanding-and-configuring-outbound-policy/15156
Problem 4
What can I do if I suspect a problem on my LAN connection?
You can test the LAN connection using ping. For example, if you are using DOS/Windows, at the command prompt, type ping 192.168.1.1. This pings the Peplink Balance device (provided that Peplink Balance’s IP is 192.168.1.1) to test whether the connection to the Peplink Balance is OK.
Problem 5
What can I do if I suspect a problem on my Internet/WAN connection?
You can test the WAN connection using ping, as in the solution to Problem 4. As we want to isolate the problems from the LAN, ping will be performed from the Peplink Balance. By using Ping/Traceroute under the System tab of the Peplink Balance, you may be able to find the source of the problem.
Problem 6
When I upload files to a server via FTP, the transfer stalls after a few kilobytes of data are sent. What should I do?
The maximum transmission unit (MTU) or MSS setting may need to be adjusted. By default, the MTU is set at 1440. Choose Auto for all of your WAN connections. If that does not solve the problem, you can try the MTU 1492 if a connection is DSL. If the problem still persists, change the size to progressively smaller values until your problem is resolved (e.g., 1462, 1440, 1420, 1400, etc.).
Additional troubleshooting resources:
Peplink Community Forums: https://forum.peplink.com/
