Appendix E. Overview of Ports Used by Peplink SD-WAN Routers & Other Peplink Services
Default Port Number | Usage | Service | Inbound/Outbound | Default Status |
UDP 5246 | Data flow | InControl | Outbound | Enabled |
TCP 443 | HTTPS service | InControl | Outbound | Enabled |
TCP 5246 | Optional, used when TCP 443 is not responding | InControl | Outbound | Enabled |
TCP 5246 | Remote Web Admin | InControl Virtual Appliance | Outbound | Enabled |
TCP 4500 | VPN Data (TCP Mode) | PepVPN / SpeedFusion | Inbound / Outbound* | Disabled |
TCP 32015 | VPN handshake | PepVPN / SpeedFusion | Inbound / Outbound* | Disabled |
UDP 4500 | VPN Data | PepVPN / SpeedFusion | Inbound / Outbound* | Disabled |
UDP 32015º | VPN Data (alternative) | PepVPN / SpeedFusion | Inbound / Outbound* | Disabled |
TCP/UDP 4500+N-1^ | VPN Sub-Tunnels Data | PepVPN / SpeedFusion | Inbound / Outbound* | Disabled |
UDP 32015+N-1^ | VPN Sub-Tunnels Data (alternative) | PepVPN / SpeedFusion | Inbound / Outbound* | Disabled |
UDP 4500 | VPN Data | IPsec | Inbound / Outbound* | Disabled |
UDP 500 | VPN initiation | IPsec | Inbound / Outbound* | Disabled |
UDP 500 | L2TP | Remote User Access | Inbound | Disabled |
UDP 1701 | L2TP | Remote User Access | Inbound | Disabled |
UDP 4500 | L2TP | Remote User Access | Inbound | Disabled |
UDP 1194 | OpenVPN | Remote User Access | Inbound | Disabled |
IP 47 | PPTP (GRE) | Remote User Access | Inbound | Disabled |
TCP 2222 | Remote Assistance Direct connection | Peplink Troubleshooting Assistance | Outbound | Enabled |
TCP 80 | HTTP traffic | Web Admin Interface access | Inbound | Enabled |
TCP 443 | HTTPS traffic | Web Admin Interface access (secure) | Inbound | Enabled |
TCP 8822 | SSH | SSH | Inbound | Disabled |
UDP 161 | SNMP Get | SNMP monitoring | Inbound | Disabled |
UDP 162 | SNMP Trap | SNMP monitoring | Outbound | Disabled |
TCP, UDP 1812 | Radius Authentication | Radius | Outbound | Disabled |
TCP, UDP 1813 | Radius Accounting | Radius | Outbound | Disabled |
UDP 123 | Network Time Protocol | NTP | Inbound Outbound | Disabled Enabled |
TCP 60660 | Real-time location data in NMEA format | GPS | Inbound | Disabled |
Disclaimer:
- By default, only TCP 32015 and UDP 4500 are needed for PepVPN / SpeedFusion.
- Inbound / Outbound* - Inbound = For Server mode; Outbound = For Client mode
- UDP 32015º - If IPsec VPN or L2TP/IPsec RUA is enabled, the UDP 4500 is occupied, so PepVPN / SpeedFusion will automatically switch to UDP 32015 as VPN data port.
- UDP 32015+N-1^ / TCP/UDP 4500+N-1^ - When using Sub-Tunnels, multiple ports are in use (1 for each Sub-Tunnel profile).
- The default UDP data ports used when using (N number of Sub-Tunnel profiles) are: 4500…4500+N-1, or (when port 4500 is in use by IPsec or L2TP/IPsec) 32015… 32015+N-1".
