18. Status Tab
18.1. Status
18.1.1. Device
System information is located at Status > Device.
System Information | |
Device Name | This is the name specified in the Device Name field located at System > Admin Security. |
Model | This shows the model name and number of this device. |
Product Code | If your model uses a product code, it will appear here. |
Hardware Revision | This shows the hardware version of this device. |
Serial Number | This shows the serial number of this device. |
Firmware | This shows the firmware version this device is currently running. |
Care Plan | Display care plan status and expiry date. Note: Refresh button to manually refresh the PrimeCare license. Users who have disabled InControl management may click [Refresh] option to check the PrimeCare license status after a renewal. |
SpeedFusion VPN | This shows the current SpeedFusion VPN version. |
Modem Support Version | This shows the modem support version. For a list of supported modems, click Modem Support List. |
Host Name | The host name assigned to the Pepwave router appears here. |
Uptime | This shows the length of time since the device has been rebooted. |
System Time | This shows the current system time. |
Diagnostic Report | The Download link is for exporting a diagnostic report file required for system investigation. |
Remote Assistance | This option is to Turn on remote assistance with the time duration. |
The second table shows the MAC address of each LAN/WAN interface connected.
Important Note |
If you encounter issues and would like to contact the Peplink Support Team (http://www.peplink.com/contact/), please download the diagnostic report file and attach it along with a description of your issue. |
18.1.2. Active Sessions
Information on active sessions can be found at Status > Active Sessions > Overview.
This screen displays the number of sessions initiated by each application. Click on each service listing for additional information. This screen also indicates the number of sessions initiated by each WAN port. Finally, you can see which clients are initiating the most sessions.
In addition, you can also perform a filtered search for specific sessions. You can filter by subnet, port, protocol, and interface. To perform a search, navigate to Status > Active Sessions > Search.
This Active Sessions section displays the active inbound / outbound sessions of each WAN connection on the Peplink Balance. A filter is available to help sort out the active session information. Enter a keyword in the field or check one of the WAN connection boxes for filtering.
18.1.3. Client List
The client list table is located at Status > Client List. It lists DHCP and online client IP addresses, type, names (retrieved from the DHCP reservation table or defined by users), current download and upload rate, and MAC address.
Clients can be imported into the DHCP reservation table by clicking the
button on the right. Further update the record after the import by going to Network > LAN.
If the PPTP server, SpeedFusionTM, or AP controller is enabled, you may see the corresponding connection name listed in the Name field.
In the client list table, there is a “Ban Client” feature which is used to disconnect the Wi-Fi and Remote User Access clients by clicking the
There is a blocklist on the same page after you banned the Wi-Fi or Remote User Access clients.
You may also unblock the Wi-Fi or Remote User Access clients when the client devices need to reconnect to the network by clicking
the button on the right.
18.1.4. OSPF & RIPv2
Information on OSPF and RIPv2 routing setup can be found at Status > OSPF & RIPv2.
18.1.5. BGP
Information on BGP routing setup can be found at Status >BGP.
18.1.6. SpeedFusion VPN
SpeedFusion VPN shows the current connection status of each connection profile and is displayed at Status > SpeedFusion VPN.
Click on the corresponding peer name to explore the WAN connection(s) status and subnet information of each VPN peer.
Click the
button for PepVPN/SpeedFusion chart displaying real-time throughput, latency, and drop-rate information for each WAN connection.
When pressing the
button for a PepVPN/SpeedFusion Tunnel Bandwidth Test Tool, the following menu will appear:
The connection information shows the details of the selected PepVPN profile, consisting of the Profile name, Router ID, Router Name and Serial Number of the remote router.
Advanced features for the PepVPN profile will also be shown when the More Information checkbox is selected.
The WAN statistics show information about the local and remote WAN connections (when show Remote connections) is selected.
The available details are WAN Name, IP address and port used for the SpeedFusion connection. Rx and Tx rates, Loss rate and Latency.
Connections can be temporarily disabled by sliding the switch button next to a WAN connection to the left.
The WAN-to-WAN connection disabled by the switch is temporary and will be re-enabled after 15 minutes without any action.
This can be used when testing the PepVPN speed between two locations to see if there is interference or network congestion between certain WAN connections.
The PepVPN/SpeedFusion test configuration allows us to configure and perform thorough tests.
This is usually done after the initial installation of the routers and in case there are problems with aggregation.
Press the Start button to perform a throughput test according to the configured options.
If TCP is selected, 4 parallel streams will be generated to get the optimal results by default. This can be customized by selecting a different value of streams.
Using more streams will typically get better results if the latency of the tunnel is high.
18.1.7. MediaFast
To get details on storage and bandwidth usage, select Status > MediaFast.
18.1.8. Event Log
Event log information is located at Status > Event Log.
Device Event Log
The log section displays a list of events that have taken place on the Peplink Balance unit. Click the
to refresh log entries automatically. Click the
button to clear the log.
Firewall Event Log
This section displays a list of events that have taken place within a firewall. Click the
button and the log will be refreshed.
SpeedFusion VPN Event Log
This section displays a list of events that have taken place within a SpeedFusion VPN connection. Click the
18.2. WAN Quality
The Status > WAN Quality allows to show detailed information about each connected WAN connection.
18.3. Usage Reports
This section shows the bandwidth usage statistics, located at Status > Bandwidth. Bandwidth usage at the LAN while the device is switched off (e.g., LAN bypass) is neither recorded nor shown.
18.3.1. Real-Time
The Data transferred since installation table indicates how much network traffic has been processed by the device since the first bootup. The Data transferred since last reboot table indicates how much network traffic has been processed by the device since the last bootup.
18.3.2. Hourly
This page shows the hourly bandwidth usage for all WAN connections, with the option of viewing each individual connection. Select the desired connection to check from the drop-down menu.
18.3.3. Daily
This page shows the daily bandwidth usage for all WAN connections, with the option of viewing each individual connection.
Select the connection to check from the drop-down menu. If you have enabled the Bandwidth Monitoring feature, the Current Billing Cycle table for that WAN connection will be displayed.
Click on a date to view the client bandwidth usage of that specific date. This feature is not available if you have selected to view the bandwidth usage of only a particular WAN connection. The scale of the graph can be set to display megabytes (MB) or gigabytes (GB).
Status
Click on a specific date to receive a breakdown of all client usage for that date.
18.3.4. Monthly
This page shows the monthly bandwidth usage for each WAN connection. If you have enabled the Bandwidth Monitoring feature, you can check the usage of each particular connection and view the information by Billing Cycle or by Calendar Month.
Click the first two rows to view the client bandwidth usage in the last two months. This feature is not available if you have chosen to view the bandwidth of an individual WAN connection. The scale of the graph can be set to display megabytes (MB) or gigabytes (GB).
Click on a specific month to receive a breakdown of all client usage for that month.
