3. Product Comparison Charts
3.1. Balance Routers (for Small Office / Branch)
20
20X
30 LTE
30 PRO
ONE
TWO
210
310X
Product Code
BPL-021
BPL-021X-LTE
BPL-031-LTE
BPL-031-LTEA
BPL-ONE
BPL-TWO
BPL-210
BPL-310X
Capacity
Ethernet WAN Ports
2 (GE) +
1 (GE)
2 (GE)
2 (GE)
2/5 (GE) #
2 (GE)
2 (GE) +
2 (GE)
LAN Ports
4 (GE)
4 (GE)
4 (GE)
4 (GE)
8/5 (GE) #
4 (GE)
7 (GE)
9 (GE)
Simultaneous Dual-Band 802.11ac/a/b/g/n Wi-Fi AP
No
Yes
No
Yes
Yes
No
No
No
Embedded 4G LTE
No
Yes
Yes
Yes
No
No
No
Yes
SIM Card Size
No
Mini-SIM (2FF)
Mini-SIM (2FF)
Mini-SIM (2FF)
No
No
No
Mini-SIM (2FF)
USB WAN Modem Port
1
1
1
1
1
1
1
2
Recommended Users
1-60
1-60
1-60
1-60
1-60
25-150
25-150
50-500
Stateful Firewall Throughput
150Mbps
900Mbps
200Mbps
400Mbps
600Mbps/
400Mbps #
1Gbps
350Mbps
2.5Gbps
A full product comparison for Balance routers is available at:
http://www.peplink.com/products/balance/model-comparison/
3.2. Balance Routers (for Enterprise / Headquarters)
305
310X
380
380X
580
580X
710
1350
2500
2500 EC
Product Code
BPL-305
BPL-310X
BPL-380
BPL-380X
BPL-580
BPL-580X
BPL-710
BPL-135
BPL-
2500 *
BPL-
2500-EC
Capacity
Ethernet WAN Ports
3 (GE)
2 (GE)
3 (GE)
3 (GE)
5 (GE)
5 (GE)
7 (GE)
13 (GE)
12 (GE)/4 (GE) & 2 (10G SFP+) *
Up to 16 (GE)*
Up to 4x 10G SFP+*
LAN Ports
3 (GE)
9 (GE)
3 (GE)
3 (GE)
3 (GE)
3 (GE)
3 (GE)
3 (GE)
8 (GE)/
2 (10G SFP+) *
Up to 16 (GE)*
Up to 4x 10G SFP+*
No
No
No
No
No
No
No
No
No
No
Embedded 4G LTE
No
Yes
No
No
No
No
No
No
No
No
SIM Card Size
No
Yes
No
No
No
No
No
No
No
No
USB WAN Modem Port
1
2
1
1
1
1
1
1
1
1
Recommended Users
50-500
50-500
50-500
50-500
300-1000
300-1000
500-2000
1000-5000
5000-20000+
10000-20000+
1Gbps
2.5Gbps
1Gbps
3Gbps
1.5Gbps
4Gbps1
2.5Gbps
5Gbps
8Gbps
30Gbps
3.3. MediaFast Routers
MediaFast 200
MediaFast 500
MediaFast 750
Product Code
MFA-200-W
MFA-500-B
MFA-750-B
WAN Interface
2x GE
(Only WAN 1 is activated.)
5x GE
7x GE
Wi-Fi Interface
Simultaneous Dual-Band 802.11a/b/g/n Access Point
Embedded 3G/4G LTE
USB WAN Modem
1
1
1
LAN Interface
8x GE; 802.3at PoE Output
3x GE
3x GE
Recommended Users
25-150
300-1000
500-2000
Router Throughput
200Mbps
800Mbps
1.5Gbps
Disk Drive
120GB SSD
500GB SSD
1TB SSD
Load Balancing & Failover
Yes
Yes
Yes
PepVPN
Yes
Yes
Yes
SpeedFusion Hot Failover
Optional Feature
Yes
Yes
SpeedFusion WAN Smoothing
Optional Feature
Yes
Yes
SpeedFusion Bandwidth Bonding
Optional Feature
Yes
Yes
Number of PepVPN/SpeedFusion Peers
2
50
300
PepVPN/ SpeedFusion Throughput
50Mbps
200Mbps
400Mbps
Built-in AP Controller
Yes
Yes
Yes
Maximum Number of AP Support
50
100
250
PoE Input
PoE Output
8x 802.3at (optional feature)
Dimensions
292 x 177 x 44 mm
431 x 305 x 44 mm
426 x 365 x 44 mm
Gross Weight
2.8 kg
6.6 kg
5.5 kgs
On this page
