Appendix A. Restoration of Factory Defaults
To restore the factory default settings on a Peplink Balance unit, perform the following:
For Balance models with a reset button:
  1. 1.Locate the reset button on the Peplink Balance unit.
  2. 2.With a paperclip, press and keep the reset button pressed.
Hold for approximately 10 seconds for factory reset (Note: The LED status light shows in RED, until the status light off and release the button)
After the Peplink Balance router finishes rebooting, the factory default settings will be restored.
For Balance/MediaFast models with an OLED menu:
  • Use the buttons on the front panel to control the OLED menu to go to Maintenance>Factory Defaults, and then choose Yes to confirm.
Afterwards, the factory default settings will be restored.
Important Note
All previous configurations and bandwidth usage data will be lost after restoring factory default settings. Regular backup of configuration settings is strongly recommended.
