12. Basic Configuration
12.1. Connecting to the Web Admin Interface
Start a web browser on a computer that is connected with the Peplink Balance through the LAN.
To connect to the web admin of the Peplink Balance, enter the following LAN IP address in the address field of the web browser: https://192.168.1.1
(This is the default LAN IP address of the Peplink Balance.) Enter the following to access the web admin interface.
Username: admin
Password: admin
(This is the default admin user login of the Peplink Balance. )
You must change the default password on the first successful logon.
Password requirements are: A minimum of 10 lower AND upper case characters, including at least 1 number.
When HTTP is selected, the URL will be redirected to HTTPS by default.
After successful login, the Dashboard of the web admin interface will be displayed.
Important Note |
The Save button causes the changes to be saved. Configuration changes (e.g., WAN, LAN, admin settings, etc.) take effect after clicking the Apply Changes button on each page’s top-right corner. |
12.2. Configuration with the Setup Wizard
The Setup Wizard simplifies the task of configuring WAN connection(s) by guiding the configuration process step-by-step.
To begin, click Setup Wizard after connecting to the web admin interface.
Click Next >> to begin.
Select Yes if you want to set up drop-in mode using the Setup Wizard.
Click on the appropriate checkbox(es) to select the WAN connection(s) to be configured. If you have chosen to configure drop-in mode using the Setup Wizard, the WAN port to be configured in drop-in mode will be checked by default.
If drop-in mode is going to be configured, the setup wizard will move on to Drop-in Settings.
If you are not using drop-in mode, select the connection method for the WAN connection(s) from the following screen:
Depending on the selection of connection type, further configuration may be needed. For example, PPPoE and static IP require additional settings for the selected WAN port. Please refer to Configuring the WAN Interface(s) section for details on setting up DHCP, static IP, and PPPoE.
If Mobile Internet Connection is checked, the setup wizard will move on to Operator Settings.
If Custom Mobile Operator Settings is selected, APN parameters are required. Some service providers may charge a fee for connecting to a different APN. Please consult your service provider for the correct settings.
Click on the appropriate check box(es) to select the preferred WAN connection(s). Connection(s) not selected in this step will be used as a backup only. Click Next >> to continue.
Choose the time zone of your country/region. Check the box Show all to display all time zone options.
Check in the following screen to make sure all settings have been configured correctly, and then click “Save Settings” to confirm.
After finishing the last step in the setup wizard, click Apply Changes on the page header to allow the configuration changes to take effect.
