9. Peplink Flex-Module Supported Models
The EPX is a rapidly deployable, powerful, and versatile SD-WAN router that connects a wide range of WAN options from LTE-A, satellite modems, to fixed line networks this can be used simultaneously to allow bonding using our SpeedFusion technology.
With its modular construction, the EPX is suitable for any deployment.
Main Chassis
EPX Main Chassis
Power Input
AC Input 100V - 240V
Power Consumption (Main Chassis only)
215W
Throughput
30Gbps
PepVPN/SpeedFusion Throughput (256-bit AES)
2Gbps
Dimensions
18.9 x 21.7 x 3.6 inches - 480 x 550 x 90 mm
Weight (No Modules)
31.3 pounds - 14.2 kilograms
Operating Temperature
32° – 113°F (0° – 45°C)
Humidity
5% – 90% (non-condensing)
Certifications
FCC, IC, CE-RED
EN 50155: Railway Applications
EN 61373:1999 IEC 61373:1999: Shock and Vibration Resistance
EN 50121: Rolling Stock EMC, Signalling and Telecom Apparatus
Warranty
1-Year Limited Warranty
Panel Appearance
LED Indicators
Status indicated in the LAN/WAN port module is as follows:
Note: some EPX configurations are not shipped with this module.
LED Indicator
Power LED
OFF – Power off
Green – Power on
LAN Port, WAN Ports
Right LED
Orange – Enabled as WAN port
Green – PoE enabled
OFF – PoE is disabled
Left LED
Solid – Port is connected without traffic
Blinking – Data is transferring
OFF – Port is not connected
Port Type
Auto MDI/MDI-X ports
Console & USB Ports
Console Port
CLI Console connection
USB Ports
For connecting a 4G/3G USB modem
The SDX is a Modular Enterprise Grade Router. In addition to popular features such as SpeedFusion SD-WAN and InControl centralized management, the SDX has an expandable module that you can change according to your needs.
The SDX includes two integrated SFP+ WAN Ports, as well as eight PoE-enabled LAN Ports.
These ports are available no matter which module you use.
Main Chassis
SDX Main Chassis
Power Input
Power Consumption
80W System*, 330W PoE+ Power Budget
Throughput
12 Gbps
No Encryption: 1 Gbps
256-bit AES: 600 Mbps
Dimensions
17.2 x 13.3 x 1.7 inches - 438 x 340 x 44 mm
Weight (No Modules)
11.7 pounds - 5.3 kilograms
32° – 104°F (0° – 40°C)
Humidity
Certifications
FCC, IC, CE
* 80W consumption for the main chassis, 20W consumption for the optional module.
Panel Appearance
Front:
Back:
LED Indicators
LED Indicator
Power LED
OFF – Power off
Green – Power on
WAN Ports
Right LED
Green – 1000 Mbps
OFF – 10 Mbps / 100 Mbps or the port is not connected
Left LED
Port Type
LAN Ports
Right LED
Green – PoE enabled
Left LED
Port Type
Console, MGMT & USB Ports
Console Port
CLI console connection
USB Ports
For connecting 4G/3G USB modems for additional WAN connections
MGMT Port
Management port
In addition to the power of the SDX, the SDX Pro offers greater flexibility and functionality. It has two FlexModule slots, enabling you to customize the device with different modules to suit any deployment. It supports edge computing so it can deliver websites, applications, and docker containers to connected devices.
Main Chassis
SDX Pro Main Chassis
Power Input
Power Consumption
140W System*, 420W PoE+ Power Budget
Throughput
24 Gbps
Dimensions
17.2 x 13.8 x 1.7 inches - 438 x 350 x 44 mm
Weight (No Modules)
15.9 pounds - 7.2 kilograms
Humidity
10% – 85% (non-condensing)
Certifications
FCC, IC, CE
* 140W consumption for the main chassis, 20W consumption for the optional module.
Panel Appearance
LED Indicators
LED Indicator
Power LED
OFF – Power off
Green – Power on
WAN Ports
Right LED
Green – 1000 Mbps
OFF – 10 Mbps / 100 Mbps or port is not connected
Left LED
Port Type
Console Port
USB Ports
MGMT Port
Management port
9.4. Flex Module Expansion Modules
9.4.1. 8x GE PoE+ Module (EXM-8C)
8x GE PoE Module
Interface
8x 10/100/1000M Ethernet Ports *
Capable of PoE+
Power Consumption
15W (255W max. with 802.3at/af PoE+ Output)
Dimensions
4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mm
Weight
1.1 pounds (475 grams)
* Module can be configured with LAN or WAN ports as needed.
LED Indicator:
Ethernet Ports
Right LED
OFF – Enabled as LAN port
Left LED
Port Type
9.4.2. 4x SFP+ Module (EXM-4F)
4x SFP+ Module
Interface
4x SFP+ Ports *
Power Consumption
11W
Dimensions
103 x 188 x 38 mm
Weight
0.83 pounds (375 grams)
9.4.3. 3x LTE-A Module (EXM-3LTEA)
3x LTE-A Module
Interface
3x Embedded LTE-A Cellular Modems with Redundant SIM Slots
Antenna Connectors
6x SMA Cellular Antenna Connectors
1x SMA GPS Antenna Connector
Power Consumption
20W
Dimensions
103 x 188 x 38 mm
Weight
9.4.4. 4x LTE-A Module (EXM-4LTEA)
3x LTE-A Module
Interface
4x Embedded LTE-A Cellular Modems with Redundant SIM Slots
Antenna Connectors
8x SMA Cellular Antenna Connectors
Power Consumption
20W
Dimensions
103 x 188 x 38 mm
Weight
9.4.5. CAT-18. 2x LTE-A Module (EXM-2GLTE-G)
2x LTE-A Module
Interface
2x Embedded LTE-A Cellular Modems with Redundant 4FF Nano SIM Slots
Antenna Connectors
Power Consumption
20W
Dimensions
103 x 188 x 38 mm
Weight
9.4.6. SIM Injector FlexModule (EXM-SIM-BK56)
* Compatible with EPX, SDX Pro
SIM Slot Capacity
56 4FF Nano SIM Cards
Power Consumption
15W
Dimensions
103 x 188 x 38 mm
Weight
1.30 pounds (600 grams)
9.4.7. 2x 5G Module (EXM-2X5GD)
2x 5G Module
Interface
2x Embedded Cellular Modems with Redundant 4FF Nano SIM Slots
Antenna Connectors
Power Consumption
20W
Dimensions
103 x 188 x 38 mm
Weight
On this page
