11. Restoring Factory Defaults
To restore the factory default settings on a Pepwave AP One router:
- Locate the reset button on the front or back panel of the router.
- Using a paperclip or similar tool, press and hold the reset button. The LED status light turns red.
- Continue holding for 10-15 seconds, until the LED status light turns off.
- Release the button. The LED status light turns back on, and the router reboots.
After the Pepwave AP One router finishes rebooting, the factory default settings will be restored.
Important Note |
All previous configurations and bandwidth usage data will be lost after restoring factory default settings. Regular backup of configuration settings is strongly recommended. |
