7. Mounting the Unit
7.1. Wall Mount
The Peplink MAX 700/HD2/On-The-Go can be wall mounted using screws. After adding the screw on the wall, slide the MAX in the screw hole socket as indicated below. Recommended screw specification: M3.5 x 20mm, head diameter 6mm, head thickness 2.4mm.
7.2
The Peplink MAX BR1 requires four screws for wall mounting.
7.2. Car Mount
The Peplink MAX700/HD2 can be mounted in a vehicle using the included mounting brackets. Place the mounting brackets by the two sides and screw them onto the device.
7.3. IP67 Installation Guide
Installation instructions for IP67 devices can be found here: http://download.peplink.com/manual/IP67_Installation_Guide.pdf
7.4. PDX Accessory Kit Installation Guide
7.4.1. Battery Set Appearance
  • Step 1: Lock the battery set in the slot with 2 pcs M3 screws.
  • Step 2: Plug power cable into the socket.
  • STEP 3: Lock the slot cover with 4 pcs M3 screws.
7.4.2. SFE-DUO Set Appearance
  • STEP 1: Assemble SMA cables to the device
  • STEP 2: Assemble bracket to the device
  • STEP 3: Assemble SMA connectors to the bracket
  • STEP 4: Lock the SFE-Duo set in the slot with 2 pcs M3 screws.
  • STEP 5: Connect DC power & ETH port
  • STEP 6: Lock the slot cover with 4 pcs M3 screws.
On this page
