6. Installation
The following section details connecting Peplink routers to your network.
6.1. Preparation
Before installing your Peplink router, please prepare the following as appropriate for your installation:
  • At least one Internet/WAN access account and/or Wi-Fi access information
  • Depending on network connection type(s), one or more of the following:
  • Ethernet WAN: A 10/100/1000BaseT UTP cable with RJ45 connector
  • USB: A USB modem
  • Embedded modem: A SIM card for 5G/4G LTE service
  • Wi-Fi WAN: Wi-Fi antennas
  • A computer installed with the TCP/IP network protocol and a supported web browser. Supported browsers include Microsoft Internet Explorer 11 or above, Mozilla Firefox 24 or above, Apple Safari 7 or above, and Google Chrome 18 or above.
6.2. Constructing the Network
At a high level, construct the network according to the following steps:
  1. 1.With an Ethernet cable, connect a computer to one of the LAN ports on the Peplink router. Repeat with different cables for up to 4 computers to be connected.
  1. 2.Connect either another Ethernet cable or a USB modem to one of the WAN ports or USB ports respectively, or connect to Wi-Fi as WAN on the Peplink router. Repeat the same process for any additional WAN ports.
  1. 3.Connect the power adapter to the power connector on the rear panel of the Peplink router, and then plug it into a power outlet.
6.3. Configuring the Network Environment
To ensure that the Peplink router works properly in the LAN environment and can access the Internet via WAN connections, please refer to the following setup procedures:
  • LAN configuration
For basic configuration, refer to Section 8, Connecting to the Web Admin Interface.
For advanced configuration, go to Section 10, Configuring the LAN Interface(s).
  • WAN configuration
For advanced configuration, go to Section 10.3, Captive Portal.
On this page
