2. Models & Specifications
2.1. 8 PoE 10G Switch
LED Indicators:
Status Indicators
Power
OFF
No power
Green (Solid light)
System boot ongoing
Green (Solid light)
System boot ready
Status
OFF
System boot ongoing / System off
Green (Solid light)
System boot ready
IC2
OFF
No link with IC2
Green (Solid light)
IC2 connected
Ethernet Ports
RJ45 Left LED (Activity)
OFF
Port is not connected
Amber ( Blinking)
Data is transferring
Amber (Solid Light)
Port is connected
RJ45 Right LED (PoE Switch)
Off
PoE disable
Green (Solid Light)
PoE enabled (even if no cable is connected)
RJ45 Right LED (Non PoE Switch)
Off
Other speed / No link
Green (Solid light)
Highest speed
SFP Ports
SFP LED (Activity)
Off
No link
Green (Blinking)
Activity
Green (Solid light)
Link
Reset Button
Hold the reset button
0 - 10 seconds
Status light (green) blinking slowly.
10 -15 seconds
Status light (green) blinking fast
Over 15 seconds
Status light off; release the reset button, and the device starts rebooting.
2.2. 24 PoE 2.5G Switch Rugged
LED Indicators:
Status Indicators
Power
OFF
No power
Green (Solid light)
System boot ongoing
Green (Solid light)
System boot ready
Status
OFF
Green (Solid light)
System boot ready
IC2
OFF
No link with IC2
Green (Solid light)
IC2 connected
Ethernet Ports
OFF
Amber ( Blinking)
Amber (Solid Light)
Port is connected
Off
PoE disable
Green (Solid Light)
Off
Green (Solid light)
Highest speed
SFP Ports
SFP LED (Activity)
Off
No link
Green (Blinking)
Activity
Green (Solid light)
Link
Reset Button
0 - 10 seconds
10 -15 seconds
Over 15 seconds
2.3. 24 PoE 2.5G Switch
LED Indicators:
Status Indicators
Power
OFF
No power
Green (Solid light)
System boot ongoing
Green (Solid light)
System boot ready
Status
OFF
Green (Solid light)
System boot ready
IC2
OFF
No link with IC2
Green (Solid light)
IC2 connected
Ethernet Ports
OFF
Amber ( Blinking)
Amber (Solid Light)
Port is connected
Off
PoE disable
Green (Solid Light)
Off
Green (Solid Light)
Highest speed
SFP Ports
SFP LED (Activity)
Off
No link
Green (Blinking)
Activity
Green (Solid light)
Link
Reset Button
0 - 10 seconds
10 -15 seconds
Over 15 seconds
2.4. 48 PoE 2.5G Switch
LED Indicators:
Status Indicators
Power
OFF
No power
Green (Solid light)
System boot ongoing
Green (Solid light)
System boot ready
Status
OFF
Green (Solid light)
System boot ready
IC2
OFF
No link with IC2
Green (Solid light)
IC2 connected
Ethernet Ports
OFF
Amber ( Blinking)
Amber (Solid Light)
Port is connected
Off
PoE disable
Green (Solid Light)
Off
Green (Solid Light)
Highest speed
SFP Ports
SFP LED (Activity)
Off
No link
Green (Blinking)
Activity
Green (Solid light)
Link
Reset Button
0 - 10 seconds
10 -15 seconds
Over 15 seconds
On this page
