2. Procedures for Changing the FlexModule Mini on the B20X
Step 1: Power off the router. The router MUST be disconnected from power before starting the upgrade.
Step 2: Disconnect all antennas.
Step 3: Loosen the screws on the cover or the installed FlexModule Mini.
Step 4: Remove the cover or module by pulling it out directly.
Step 5: Install the new module. Make sure it is correctly aligned before pressing the module
firmly into place. The FlexModule Mini should sit flush with the router chassis.
Step 6: Tighten the screws until the FlexModule Mini sits flush and tight with the collar.
Step 7: Reconnect the antennas.
Step 8: Reconnect the power.
