Pepwave MAX Adapter User Guide#
User Guide
Pepwave MAX Adapter:
MAX Adapter
MAX Adapter: 2.0.0
January 2023
Specifications#
MAX Adapter | |
Cellular WAN Interface | Single LTE Modem |
Redundant SIM Slot | Yes |
Downlink / Uplink Data Rate | CAT-12: 600Mbps / 150 Mbps
CAT-6: 300Mbps / 50Mbps |
Antenna Connectors | 2x SMA Cellular, 1x SMA GPS |
Power Input | 5V USB-C |
Power Consumption | 5W (nominal), 8W (max.) |
Dimensions | 3.9 x 2.8 x 0.6 inches / 100 x 71 x 15 mm |
Weight | 120g |
Operating Temperature | 32° – 104°F / 0° – 40°C |
Humidity | 15% – 95% (non-condensing) |
Warranty | 1-Year Limited Warranty |
Certifications | FCC, CE, IC |
Package Content | MAX Adapter, 2x 2dBi 4G LTE Antennas, USB-C power cable |
MAX Adapter | |
Downlink / Uplink Data Rate | 5G: 4 Gbps / 700 Mbps
LTE CAT-20: 2 Gbps / 150 Mbps |
Antenna Connectors | 4x SMA Cellular |
Weight | 120g |
Package Content | MAX Adapter, 4x 2dBi 4G LTE Antennas, USB-C power cable |
Installation Procedures#
1. Download the connection manager manually using the link below: https://www.peplink.com/support/downloads/#max-adapter OR > here <
Peplink Connection Manager installation:
Tick the “I accept the terms in the License Agreement” before clicking the “Install” button.
Wait for the installation to complete.
Tick “Launch Peplink Connection Manager” and click “Finish” after the installation is complete.
This is the User Interface of the Peplink Connection Manager after launching the application.
2. Connect the USB-C power port to the laptop in order to power the MAX Adapter via USB-C cable.
3. Wait for the status LED to turn green and begin blinking.
4. You may manage the MAX Adapter settings via Peplink Connection Manager on the laptop.
Peplink Connection Manager#
The following screenshots are from the user interface of the Peplink Connection Manager after you have powered on the device with a SIM inserted for connectivity. You may choose which connection that you would like to use for the MAX Adapter with either a local SIM (which is SIM Slot A or SIM Slot B) or an eSIM for connectivity.
The section contains SIM status, general device information, throughput and usage (KB).
You may configure the SIM settings, system settings, and view the device information by navigating to the “Advanced” button.
Click “More” to show more details about the SIM information such as “IMSI”, “ICCID”, “MTN”, etc. You may click the “Edit” button under “Opr. Settings” to configure the APN settings of your connection.
This Operator Setting allows you to configure the APN settings of your connection. If Auto is selected, the mobile operator should be detected automatically. The connected device will be configured and the connection will be made automatically. If there is any difficulty in making a connection, you may select Custom to enter your carrier’s APN, Username, and Password settings manually. The correct values can be obtained from your carrier.
The default and recommended setting is Auto.
You may change the system settings such as “Language”, “Auto-Launch on Login”, “Auto Connect”, and “SMS Notifications” by navigating to the “Settings” tab.
You may go to the “About” tab to view the device status and general device information such as “Serial Number”, “SW Version”, “Uptime”, “Signal Strength” and “Signal Quality”, etc.
You may view more device information such as “HW Revision”, “SW Revision”, and “IMEI” by clicking on the “More” button.
Setup on Linux Distributions#
The following screenshots are from the user interface of the Linux distributions and describes the steps to setup the connection for the MAX Adapter on Ubuntu 20.04.1 TLS.
- Download the Linux distributions software and install it.
- Launch Ubuntu and connect the MAX Adapter via USB to your laptop.
- When the MAX Adapter is connected, expand the “Mobile Broadband” dropdown menu by clicking on the right hand, and select the Mobile Broadband Settings. Alternatively, you may go to Settings.
- The page will navigate to the Network settings after clicking the Mobile Broadband Settings. You can select “Add new connection” from the dropdown menu to set up the mobile broadband connection profile.
- After selecting “Add new connection”, the mobile broadband profile setup will pop out. Click “Next” to continue.
- Select the provider’s country or region and then click Next.
- Select your provider from the list or set up the connection manually if your provider isn’t listed.
- Choose your data plan from the dropdown menu and it will auto-select the APN. Alternatively, you may customize the APN. The correct value can be obtained from your provider. Once completed, click Next.
- Once setup is complete, confirm that the mobile broadband settings are correct before clicking “Apply”.
- After clicking “Apply”, the mobile broadband will connect to the Internet using the MAX Adapter and you can start browsing the Internet.
Appendix#
FCC Requirements for Operation in the United States
Federal Communications Commission (FCC) Compliance Notice:
Federal Communication Commission Interference Statement
Any change or modification not expressly approved by the party responsible for compliance could void the user’s authority to operate the equipment.
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules.
These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications.
However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
- Reorient or relocate the receiving antenna.
- Increase the distance between the equipment and the receiver.
- Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
- Consult the dealer or an experienced radio/TV technician for help.
Radiation Exposure Statement
This equipment complies with FCC RF radiation exposure limits set forth for an uncontrolled
environment. This equipment should be installed and operated with a minimum distance of 20
centimeters between the radiator and your body.
Industry Canada Statement
This device contains licence-exempt transmitter(s)/receiver(s) that comply with Innovation, Science and Economic Development Canada’s licence-exempt RSS(s). Operation is subject to the following two conditions:
(1) This device may not cause interference.
(2) This device must accept any interference, including interference that may cause undesired operation of the device.
Le present appareil est conforme aux CNR d’Industrie Canada applicables aux appareils radio exempts de licence. L’exploitation est autorisee aux deux conditions suivantes:
(1) l’appareil ne doit pas produire de brouillage, et
(2) l’utilisateur de l’appareil doit accepter tout brouillage radioelectrique subi, meme si le brouillage est susceptible d’en
This device complies with the ISED radiation exposure limit set forth for an uncontrolled environment. This device should be installed and operated with minimum distance 20cm between the radiator & your body.
Cet équipement est conforme avec l’exposition aux radiations ISED définies pour un environnement non contrôlé. Cet équipement doit être installé et utilisé à une distance minimum de 20 cm entre le radiateur et votre corps.
Mounting the Unit
Wall Mount
The MAX Adapter can mount on the wall with screws. After adding the screw on the wall, MAX Adapter’s bottom hole slide to the screws as indicated below. Recommended screw specification M3.5 x 20mm, head diameter 6mm, head thickness 2.4mm.
The MAX Adapter requires two screws for wall mounting.
CE Statement for Pepwave Routers ( MAX Adapter 5G For EM9191)
WWAN : Refer 3GPP TS 36.521 -1 ( UE Power class )
This equipment complies with CE radiation exposure limits set forth for an uncontrolled envi- ronment. This equipment should be installed and operated with a minimum distance of 20cm between the radiator & your body.
contact as: https://www.peplink.com/
UK Statement for Pepwave Routers ( MAX Adapter 5G For EM9191)
